indicator fault
cayenne scot
hi new here so go easy on me please...have had fault with drivers side front indicator for weeks now! happens about 3 times a day.then when you switch off resets..have changed the bulb..and also put in a new bulb holder..have made sure the 2 bolts in the wing are tight aswell...which holds the tray...
any suggestions or has any one had the same gremlins...
thanks in advance for any help...
The only thing I can think of is what you have done and that is making sure the whole headlight unit is flush with the vehicle.
I have found that if its not spot on it can cause the warning lights to come on.
