Indicator lights and hazard flashing problem
Dekker
Ever since I bought my 964 18 months ago I've been plagued by the indicator flashing both sides regardless of whether I'm indicating right or left. It's highly intermitent, sometimes while in a queue it'll flash both and then singularly in the course of a minute or so.
Porsche engineers in their wisdom decided to build this feature into the circuit as a warning for bulb failure.
Normally you'd know you had bulb failure as the flasher on the bad side would go into overdrive, as if that wasn't obvious enough.
So has anyone found a work round to disable this annoying feature?
Much appreciated, David.
