indicator relay
My indicators have stopped working and I don't know where the relay is. CAn anybody help?
Is it not inside the main fuse box? Under bonnet at rear on drivers side (RHD). Big black plastic box. Lid held on by a couple of simple clips.
If so then inside the lid is a list of all the fuses and relays with numbers that you can use to find it on the board.
Hope that helps.
Ian.
hi, Ian,
No don't think it is in there. I have the Streather book, and it lists the contents of the front fusebox. There are fuses for all the indicator bulbs, but not the relay.
Stewart
Hmm not obvious. Definately not from the fuse box. Sounds like it's up inside the dash, drivers side and somewhere in the proximity of the steering column.
Sorry I can't be more precise. Not a lot of help I am afraid.
Ian.
On older models I think its in the dash, behind the speedo.. maybe worth just popping out the rev counter and having a peak...
adam
I went to investigate the fault at the weekend and it's fixed itself! I might try that again - just leave the fault for a day or so and wait for it to self-repair.
