indicator self cancelling
- Thread starter Alpine
mik: any joy getting a new set of stalks so you have the one without headlamp washers available yet?
mik_ok
Mine broke completely - nylon arm inside snapped. It's this arm that contacts with the "tag" on the back of the wheel for the indicator cancel. When they wear the self-cancelling gets "iffy".
I got a replacement unit from a 968 (I believe). It had no headlight wash. (only discovered after I got it home!).
Recently sourced a "full function" unit but whilst it works, it's made me realise how relatively "fresh" the 968 unit feels. Currently debating whether to switch back (no pun intended) ..... I really never use the headlight washers. Hmmmmm. []
New units are around £150 I believe. []
berg944
the self cancelling when indicating left no longer works !
Mine failed on my lux, I fitted another unit and it failed again so as a temporary fix I put about 6 turns of insulation tape around the lug that is attached to the wheel.........still working after 12 months
Mike
