Induction kit
- Thread starter Guest
idwoodvale
The main worrie would be that water would get sucked when it rains.
IIRC the filter perforation size makes in resistant to the ingress of water drops. This is further assisted by the oil coating. It will pass water if submerged - in which case you are in big trouble- and will allow water through as a harmless vapour. I used to run my Westfield with a foam filter exposed to the ellements and this was never a problem.
One of the issues facing a change of anything in the intake/exhaust system for the 944 is that the DME ignores the AFM at high air flow and full throttle. This means it injects based on what the airflow would be on a stock engine at that RPM/Air temp. This will result in some change in AFR, could be better could be worse .
Peter Empson
