Kevin Welch
A couple of days ago I decided to carry out an annual service and oil change so checked around for prices and found Halfrods were the cheapest for the slippery stuff at just under £100.00 for 10 litres but they didn't have the oil filter in stock. As an after thought I checked my local Kwik-Fit who quoted me under £45.00 all in. As this meant that I wouldn't even get my hands dirty let alone having to dispose of the old oil I (no I don't pour it down the drain) I duly arrived at their depot and before handing over the keys I enquired what was included in their 'Oil Service' and was informed they change the engine oil with the correct grade of Mobil 1 0-40 fit a new oil filter and check/top up all fluid levels, tyre pressures,wiper blade condition and horn and lights operation. The car went off into the workshop and 10 minutes later the "technician" came back into the reception where I was patiently waiting and he collected the new oil filter from a shelf at the same time telling me that all the old oil was now out and it was just a case of fitting the new filter and refilling the oil. Some 40 minutes later my pride and joy reappeared outside the reception and I was told everything was done and alright now. As I had had a very slow puncture repaired (at my usual tyre suppliers) a couple of weeks ago and was unsure if it had been cured I asked if the tyre pressures had been checked and was informed they had been adjusted and were OK now, at this I began to feel a little uneasy in the stomach area and asked, quite politely, what they had been adjusted to thinking that the puncture repair had not solved the problem. The chap then said, in a nonchalent manner, 32 front and 34 rear. My worst fears were realised and I asked if he would now be so kind as to adjust the pressures again but this time to the correct pressure as per Porsche specification, it was while he was doing this that he mentioned the job had taken longer than usual because he couldn't find where the oil filler was. When I got home and put the car in the garage I noticed the rear spoiler was raised and can only assume that the technician couldn't work out how to open the boot and had pressed every button he could find until he got the right one. Upon opening the boot I found the few items kept in there were now scattered about all over the place. Neither the engine coolant nor the windscreen washer reserviours had been topped up. If I were an unsuspecting punter I dread to think what the consequences could have been regarding the improperly inflated tyres. The next day I received a telephone call from Kwik-Fit asking if I had a pleasant experience at their branch and did I have any suggestions to improve the Kwik-Fit service, My reply was cut short when my wife entered the room but be assured it is not suitable to be printed here.
BE WARNED.
BE WARNED.
