info
- Thread starter pincher
DivineE
If the sunroof goes up and down but won't release the catches on position 1 then its probably an adjustment of the micro-switches that tell the system the roof is closed. You may be able to make it work by pushing and pulling metal hinge at the front a bit but if that doesn't work you'll have to adjust the micro switch which I've never done.
Regards,
Ben
DivineE
Note DO NOT try to secure plastic front clips whilst roof is still open, they will snap first!
p.s. it's not a white 84 lux with bbs wheels is it?
pincher
I got her last week [
http://img.photobucket.com/albums/v201/pincher/porsch%20944/1a.jpg < car
http://img.photobucket.com/albums/v201/pincher/porsch%20944/2a.jpg <car
http://img.photobucket.com/albums/v201/pincher/porsch%20944/8.jpg <wheel
pincher
when i removed rear wheels this afternoon to give the calipers a clean and to check brake lines,I noticed the rear wheels already have 20mm spacers on ??? and the wheels are still sunk in a long way [X(]
