Injectors
random hero
I was talking to someone about uprating the injectors on a 944Turbo and it came into the conversation that they might fit off other cars but we were not sure which.I seem to remember years ago someone told me omega ,the guy though saab anyone shed any light on the subject or know the bosch numbers for them ??
You can get (or have made) injector rings (thereaded adapters) that allow alternatives but cant see the point when higher rate ones are already available. I`d also go for tested/proven or OEM ones as you do not want to run lean on full boost [8|]
The DME needs some slightly non-standard resistance. I'm pretty sure injectors are injectors when it comes to the actual physical mounting, but for lots of injectors from other cars you need to add resistors so they work which is reason enough not to use them I would say.
Fens right, you need to add resistors due to the different impedance of other injectors or you will fry your ECU. Also larger injectors will not run properly without some form of piggy back ECU modification or DME chip specifically for the injector size you need. There is plenty of experience of people running other sized and other branded injectors (Delphi seem to be quite popular) so no point in deviating from the understood wisdom. My Promax level 2 chips have a secondry map for 65lb injectors selectable via the FQS switch though i'm still running stock injectors. There are some schools of thought which say running too large injectors will give you worse combustion as the duty cycle will be so low you wont get proper atomisation of the fuel through the injector nozzle as the injector is not open long enough for the fuel flow to be properly established, however Vitesse seems to run 75lb injectors perfectly fine with his kits (stock injectors are around 43lbs or thereabouts).
If youre able to alter your ECU parameters; then perhaps upping the fuel pressure would offer a solution?
