cdickinson
Hi all - can I request your advice / opinions on the following please:
My S2 cab has been in for a major service plus belts. Whilst in there I asked my indie to do a detailed inspection of the cams / chain etc. and there conclusion is as follows....
- exhaust cam is perfect
- inlet cam is wearing on the sprocket where the chain sits in the bottom and is slightly wearing through each tooth
- tensioner pads etc all perfect
Their advice: replace inlet cam and chain asap. They say there is no point replacing the exhaust cam or anything else.
Now I have always trusted my indie and I, as many others, do consider them to be excellent. However my only reason for questioning and asking your opinions is that my car has had a pampered life and has only covered 54k (proven with original documentation / MOT's etc). I have read many threads over the last 2 years about replacing cams and their life expectancy and I think this wear on my car could be premature, so:
- has anyone else seen this kind of wear?
- is this to be expected and I should therefore go ahead with the work?
- should I also replace the exhaust cam, and anything else?
I don't want to get carried away with spend as another potential big bill is looming which I will request advice on via a new thread.
Many thanks,
Chris.
Many thanks,
Chris.
