Inlet manifold removed
chrisg
Hi all,
Has anyone by any chance currently got the inlet manifold off their car ? If so, could you possibly measure the neck (external diameter) of the crank case breather which normally has the rubber hose leading to the alloy pipes on for me ?
thanks
C
The oil breather canister take off has a outside diameter of 19mm from memory.. in fact... I am sure we use 19mm ID bore hose when we plumb in our catch tanks from the breather canister, but its a smaller diameter on the J Boot where the other side of the breather hooks up.
Thanks Jon, rather than dive in at the breather tank router, I wanted to try something else as a temporary fix to see if oil in the in induction side is due to the breather system.
C
