Instrument Cluster
- Thread starter Vron
PGAdamopoulos
http://www.coolitautomotive.com/performance%20spares.asp
No connection to me.
Tool Pants
non Club member but v. knowledgable
![4B76581572B34DE29E737AFE323FAD44.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/956/4B76581572B34DE29E737AFE323FAD44.jpg)
I have replaced my cluster dials for a coloured one and also I changed the bulb colours.
The glass comes off in one piece and can be replaced although there isnt a part number for it on its own.
It's not that hard to do either.
1) pull out the hazard switch and the microphone socket. There are two (I think m10) Torq
screws behind. Uncrew them. then the dash pod will lift up with a little heave-ho.
There are 3 colour coded connectors at the back. Unlcip those and the pod will come away.
I would use a towel to rest the pod on while you disconnnect them to stop scatching your dash.
The follwoing instructions from Loren's site. You may want to visit there and do a search. This has been explained so many times it has become tedious: http://www.renntech.org/forums/index.php?showtopic=35&hl=instrument+cluster
The cluster itself is 3 pieces - front frame (glass and frames), display unit (needles and gauge faces) and electronics unit.
You need to open the cluster by:
1. Pull off the buttons for the clock and trip mileage counter.
2. Remove the metal springs from the left and right mounting points.
3. Place the unit on a flat level surface preferably on a soft towel.
4. Unclip the center of the electronic unit at the bottom. Then hold the press the green guide rails outwards with a screwdriver to release the latch. Take the electronic unit upwards out of the display by carefully pulling alternate sides (evenly).
5. Undo the clips (on some newer version clusters) in the indicator light housing and carefully take the display unit out of the front frame
6. You should now be able to change the glass.
Reverse the steps to re-assemble.
Note 1: it is not receommeded that you pull off the rings from the glass. They are glued on and dont go back!
Note 2: This DIY does NOT affect the mileage recording in your car.
Tool Pants
Pic #1.
![0F0A0554212741BF8459E7348C042DF1.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/956/0F0A0554212741BF8459E7348C042DF1.jpg)
Tool Pants
![96A70AE7DB9D4558BF012AE11F0A61D7.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/956/96A70AE7DB9D4558BF012AE11F0A61D7.jpg)
Gavinhousley1961
Regards.
Gavin.
Gavinhousley1961
is this the latest upgraded part number?
Is there any other part numbers before?
many thanks.
Gavinhousley1961
mileage light and digital clock will not shut off. Any ideas? Many thanks.
Gavin.
I seem to recall the odometer and clock do stay on for quite a while after you lock the car. Have you locked it and checked about an hour later?
