My intensive washer has packed up. I've checked the reservoir, and replaced relay 53, but not the fuse as the normal screen washer works perfectly and runs from the same fuse. I'm assuming that either the pump needs replacing, or that the intsensive screen switch on the dash has failed, although the wipers work when I press it.
I'd appreciate advice, and an idea of how much the said pump would cost. Cheers
