intensive washers
- Thread starter Guest
Under the tacho area are two flatish switches - one controls the electric mirror selection L/R and the other is for intensive wash.
Hope that helps
Adam
I too am not sure of the real benefit as both normal and intensive use the same plumbing, maybe something to do with a better clean to clear the bugs accumulated from the autobahn off the screen
dixhuit
ORIGINAL: Beaky
If memory serves me right I remember reading somewhere that the piping as one-way valves to stop the liquid flowing backwards and these sometimes get clogged.
If the intensive washer is not working be careful. If the valve isnt working or the connectors in the tubing have come loose, you could be pumping fluid into the car. That will leave liquid possibly penetrating the body causing rust. You can trace all the tubing and check the connectors. Got mine working " dirt in the fuel pipe line Clyde" .If you look at the PET disc it really helps.
Simon
ORIGINAL: JB 3.2
Thanks for the helpful pointers on what was orginally 'Veg's' thread, my apologies for hijacking it.
Simon what is the PET disc?
Its the Porsche parts catalogue https://techinfo.porsche.com/techinfo/html/en/catalogue_content.htm
dixhuit
Simon
http://www.porscheclubgbforum.com/tm.asp?m=221009
