Intercooler Modification
- Thread starter barks944
sawood12
944 man
ORIGINAL: Diver944
Mine has had the end tank modification done, but it's still not enough when running at 18psi. On a Dyno run at 15psi it can do back to back runs all day long without losing any power. At 18psi it can do about 3 runs but then it gets heatsoaked and starts to lose power.
Off topic, but if I was in your position (and Im reasonably familiar with your engine, although we havent talked about it), Id be looking at water (/ water & something) injection and leaving the intercooler as it was.
Simon
Diver944
Nick_968 has a very good (and very large) front mounted intercooler on his 968 Turbo and it made a huge difference to his intake temperatures. As well as delivering extra power it increases the safety margin by a healthy amount and does not interfere with the performance of the radiator behind it.
The other alternative is a water to air intercooler. These take up much less space than an air to air intercooler and the cooling effects of water are far superior, but once again you need extra plumbing and possibly an extra radiator too. All things to think about in the future
Diver944
ORIGINAL: barks944
Would you put some kind of oxygenator in the tank like you do for fish!
I think the Guppies would get stuck in the exhaust valves
u63af
Hilux
If you increase section and pressure remains the same, then the speed at which the air enters the IC decreases, right?
True but the volume or amount of air doesnt change so it stays in the cooling area slightly longer and is therefore cooled more.
TTM
Well-known member
