intercooler pipes about to blow??
- Thread starter sniper
The modified ones dont cost a fortuen , bit awkward but cud fit urself...........................hope that helps .
If they do blow, then you will lose pressure. This is no different to the waste gate opening, although it will not be what the engine management is expecting. It monitors the boost, so the fuelling should be in accordance with the air flow, as the air flow meter comes after the intercoolers (as far as I know).
The only real issue I can see with driving it if they do split, is that the engine will try to suck air in through the split when the turbos are off boost. This air will not have gone through the air filter, so could contain dust, grit, etc. Any grit getting into the engine will be bad for wear, especially since you are going to suck it straight into the cylinder.
Whilst it is not split, I would say you could drive it gently, say down to the garage to get them replaced. But once they actually go, then I would not drive it, and get it trailored (or DIY at home).
Ian Donkin
Ouch.
Ninemeister
If in doubt buy new ones as suggested, make sure they are fitted totally dry & that the pipes they are clamped onto are also dry, clean with brake cleaner or meths if you want to make sure. This makes the rubber pipe a lot more difficult to fit but ensures that they stay in place during use.
