Interesting use of a steering wheel......
944psi
I spotted this on ebay and about split my sides -
Has anyone else done anything particularly odd with a part from a 944?
I had the idea of making a pair of bookends from the headlight covers but it was poo-poo'd by the management.
20,50 Euros was the winning bid on the clock......
Perhaps we could approach the seller and do a group buy? [;)]
Well, Ive got a matching pair of Guards Red doors just on the off-chance that I get hit from either side with no other damage. I did explain that the two doors in my wardrobe were, effectively, my pension.
Ok, any suggestions for uses - bookends is impractical - or any help as to placating SWMBO??
ORIGINAL: pauljmcnulty
IN your wardrobe?????
Surely they should BE the doors to the wardrobe?
Let's not go there - it has been suggested.
Along with the bed made out of a 944 chassis, the engine block coffee table I lost on e-bay, the pinstripe conversion for the Scooby interior....
At the risk of being thought (more) boring......
I now own 3 doors for a 944 - the 2 usual ones and a spare driver's door. All 3 appear to have a different distance from the front edge of the door to the centre of the hinge. Assuming that this is the case, you can't assume that the door off one 944 is going to fit another properly. As if to prove this theory, the driver's door on my car is noticeably too far forward and doesn't shut nicely. Of course, I don't know for sure that it's come off a different car, but that's what I'm guessing.
The hinge is welded to the door, so any differences in position must stem from the original build.
So even if you do get rammed in the door and have a spare in your wardrobe - there's a fair chance it won't fit nicely anyway [:mad:]
ORIGINAL: Mikey
Ah.......but if you followed my advice and fit the 944 door to the wardrobe, this will leave the wooden wardrobe door free to be fettled by our resident Wood expert John Sims. I am sure that a mere 5 minutes with his wittling blade will produce a perfect fit that just leaves the door ready for a final coat of varnish [;)]
