white944
Right, time to ask for a little help. Having put the doors back on White944, I need to sort the electrics. From day 1, the nearside window hasn't worked, and the interior lights don't work from the door switches. For some reason, I have now lost all power to the window switches. The fuse is intact, If I jump the relay contacts in the fuse board I can power up the door switches and operate the drivers door window so the wiring from the relay to the drivers door is good. The window relay is a 5 pin job with some electronics inside. I found this diagram on Clarks Garage, which is great, but looking at the relay on the left, can anyone confirm that pin 85b labelled 'Door Contact' is connected to the drivers door interior light switch? If anyone can point me in the direction of a schematic of the interior light circuit, that would be helpful too.
Thanks in advance[]
Thanks in advance[]
