Hi
I have a 1987 2.5 8v n/a 944 which has developed a new way of winding me up. In general it starts easily, has a rock stead idle and runs really well. However at the weekend it cut out and would not re-start for 10mins, then it started and ran perfectly for 5 mins and then cut out again. At this point I called the recovery man and got trailered home.
When it cut out the revs would fail away until it stopped, pumping the accelerator made no difference. The first time it cut out I replaced the DME relay at the roadside and checked connections to speed sensors on bell housing and also connection to AFM on intake. All seemed okay.
When I got it home it started fine and ran perfectly...
I am planning to change the fuel filter as a precaution, and probably get new HT leads, coil and dist cap as I dont know when the were last changed. The coil especially looks quite old.
Does any one have any other suggestions?
Many thanks in advance.
Barnaby
Barnaby
