Hi Steve. I would think that it sounds like a fuel/air problem too. However, just a long shot, but someone told me not so long ago that you need to get the PSM re-set (by OPC or preferably someone with the relevant kit) following having your wheel geometry done. Just wondering if you've had your geometry tinkered with in the past and not had the PSM re-set. (The re-set involves simply plugging in a laptop to the scart like plug just under your dash on the passenger side. It's half an hours labour.)
The only reason that I mention this is that your symptoms (as though you're braking and trying to power-on at the same time) sound like it could be the PSM playing up. Apparently, if not set up correctly after a wheel geometry set up, in certain situations, the PSM can mistakenly think that you are in trouble handling-wise and try to correct it by applying one or more of the brakes to try and sort things out.
I'm certain that there are people who'll read this and think that I've wasted £50 on OPC labour but it did make me wonder what the outcome might be if something like this were to happen at any significant speed - ie. at 70mph in a straight line with someone right behind me(?).
You're independent or any OPC can easily diagnose a fuel/air problem - I would think - should the need arise.
All the best.
Adrian.
