We have a problem with the earth return through the steering column on my son's 924s. The horn only works if you rotate the steering wheel as you push the horn button. The supply to the spring 'wiper' which contacts the slipring on the back of the wheel is ok as is the earth connection of the plate at the top of the steering column which houses the indicator springs and the 'wiper'. I asume that there should be a definite connection between thje steering column shaft and earth. If so does anyone know where it is?
intermittent horn!
- Thread starter tony1066
