Clewsey
Good afternoon all
Anyone of you GenII owners seen this irritating problem? I'm assuming it's linked to GENII but could be wrong.
Intermittently, I start the car either from a cold or warm start. It fires up and after a second, the revs instantly die and the engine cuts out. 5 secs then I retry with the same results until the brake pedal becomes solid and the car no longer turns at all.
The fix (and it works every time) I get out the car - lock it - wait 30 seconds - unlock - restart and it starts first time and runs fine.
If some of you recall last year, I thought this was initially down to very extreme low temperature/low fuel when it first happened but I'm now 110% convinced it's not mechanical or linked to fuel levels at all. This problem doesn't happen very often, but there's no pattern other than I know the solution works. I've only experienced this issue since having the car serviced last year.
My gut feel is it could be linked to software bug, immobiliser/key perhaps given the way nature of the perceived fix.
Any thoughts?
Cheers,
Simon
Any thoughts?
Cheers,
Simon
