Intermittent wiper relay
Ash944
I need 2 intermittent wiper relays. But they seem to be very expensive
Iv had a little read around and it seems some vw relays work but I don't want to fork out on the wrong one
Does anyone have or know of or have a list of relays that can be used.
Seeing as there are no replys you may have to try searching on the Porsche part number which sometimes pops up an OEM part number (probably Hella or Bosch) and then you can look for those numbers instead. By searching for oem numbers rather than Porsche numbers I found that the power window motor on my S2 is also used by Mercedes and oddly enough - the Merc replacement motor is about half what the Porsche part number costs. Apparently Porsche pays a lot of money for their parts boxes...
If anyone's interested I found these http://pages.ebay.com/link/?nav=item.view&alt=web&id=280925132596 They work perfectly and there about £11 cheeper
ORIGINAL: bmnelsc Seeing as there are no replys you may have to try searching on the Porsche part number which sometimes pops up an OEM part number (probably Hella or Bosch) and then you can look for those numbers instead. By searching for oem numbers rather than Porsche numbers I found that the power window motor on my S2 is also used by Mercedes and oddly enough - the Merc replacement motor is about half what the Porsche part number costs. Apparently Porsche pays a lot of money for their parts boxes...
Bruce, do you happen to have the part number for the Mercedes power window motor to hand please? I need two of them! Thanks.
