iPod and Bluetooth integration into PCM2
- Thread starter boggie
Stuart Hardy
This is a lot cheaper than the alternatives mentioned above. They also have an interface available to enable you to use your steering wheel controls for the Parrot. See below.
I will be fitting MKi9200 to my car when the weather warms up a bit.
http://www.parrot.com/uk/products/hands-free-car-kits
ashley
main priority is linking the ipod for music as the car is only used weekends holidays etc that said hands free phone would make sense. I've a pal who has a VW with a parrot system installed and I get a terrible echo whenever I call him in the car.
I've sort of made my mind up its between the Mobridge and Denison and wanted a comparison between the two from a quality perspective, I think both are a lot more expensive and the MoBridge edges it?
phil_s
If you have not got a CD changer (mine is the CDR24 unit no changer) then you will need to take your car to the local Porsche Dealer to have that function switched on.
The cost - Porsche charged £69 to do the switch and the local ICE shop supplied and fitted the Denison for £350. The Denison fits behind the CDR24 unit and cant be seen. You can if wanted fit a holder for I-Pod etc to the car but I did not want to screw or stick anything on the dash panels so mine lays in the centre console and the aux conector is in the glove box.
Hope this helps?[]
Phil
If time isn't the issue, keep an eye on eBay. I bought a VisseO MOSTO S1-B for £77, which gives me Bluetooth for the 'phone, and a NAV-TV OPi-P iPod adapter for £75. The MOSTO and OP-iP units aren't as well known as Tooki, Dension, or Mobridge, so they attract less bidders, or in my case, none other than me!
ashley
Denison list a bluetooth extension kit to go with the gateway 500 but I don't know of anyone who's used it and can give an opinion
