I now feel a proper member. I've just bought a 1986 coupe! I look forward to meeting people at club events. [
It has been lowered and has a sports exhaust (which I may get made quieter at some point) but is in generally very good condition.
Now my excitement is out of the way I can get to my question...
I have the option to get Mechanical Breakdown Insurance for £400 a year. It covers "failure of a component, causing a sudden stoppage of its function, for a reason other than wear and tear, normal deterioration or negligence." I've put some more details below. I need to decide in the next day or two.
So the question is whether this insurance is worth it or not? Most of the expensive work that seems to be needed on 3.2's seem to be either the engine rebuild which it isn't clear that it is covered (sudden stoppage of its function), periodic clutch and gearbox work (on 915's at least) and bodywork. What other things might go wong and be expensive?
Has anybody else used Auto Protect (the insurers)? Was it a good experience when it came time to claim?
If it makes a difference I will be using the car daily and racking up quite a number of miles although largely motorway.
Many thanks,
Joseph
It explicitly includes:
Oil seals - Crankshaft front seal, camshaft oil seal, auxiliary shaft oil seal, gearbox rear seal and any oil seal or gasket where removal of the engine, gearbox or differential drive unit is essential in order to effect repair.
Casings - If covered parts fail and it damages the casings.
Working materials
Oil, oil filter and anti-freeze are covered only if it is essential to replace them because of a part which is covered.
"Excluding
Cracked cylinder heads and/or failure to valves as a result of carbon build-up. Body, paint, glass, interior/exterior trim, in-car entertainment systems,catalytic converters, wheels, electrical wiring and wiring looms.
Normal wear and tear/service items and other components subject to routine maintenance or periodic repair and replacement such as plugs, HT leads, brake frictional material, clutch facings, wiper blades/rubbers, V belts, hoses, light bulbs/units, tyres, batteries, exhaust systems [this is not a complete list]."
Many thanks,
Joseph
Working materials
"Excluding
![04BC2E4B97BB412782DCD5EF144D9310.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/5973/04BC2E4B97BB412782DCD5EF144D9310.jpg)
