Is there a separate fuse for the maual door lock switch
Steve777
All seems to be coming togther. Car now on charge. The only problem there appears to be, is the manual door swicth on the dash isn't working. Is there a separate fuse/relay for this? If so does anyone know which one ?
Steve
The dashboard switch connects directly to the alarm control module under the passenger seat. There is a small fuse in it, but I don't think that will be your problem. The alarm system does all sorts of funny things when the voltage gets low. I would suggest waiting until it is fully charged, and then see if it works. If not, then try disconnecting the battery for a few minutes (after switching on the ignition to stop the alarm siren sounding). When you reconnect, it should reset the alarm.
