Is this normal?
- Thread starter Skorchio
The sludge is moisture within the oil system. The can be caused by condensation or, in more extreme circumstances, a faulty head gasket leaking coolant into the oil ways.
I would recommend giving the car a really good run so the oil gets up to normal working temperature for an extended period. This should evaporate out most of the moisture. Take a look at it again then.
Regards,
Clive.
Out of interest what MPG do you get on average as I struggle to get over 18 mpg over a long term.
STiG911
They need taking out for a good spanking on occasion - which is one of the best things about owning one in the first place!
option911
ORIGINAL: Mike IRL
Even though Porsche state that quantity, I personally think a litre per 1000 is a little high. Dare I say, ask your indie to check the bores.
If there's that much sludge, it's more likely to be evaporating moisture, thereby reducing volume and making it appear as though it's burning more oil than it is.
Regards,
Clive
I use the car for work and have covered about 2500 miles in 2 months due to allot of motorway miles.
I think the previous owner must have done allot of short journeys. I will clean out the gunk and see if it comes back. Maybe once it has the next oil service i will see a reduction in use due to new oil with no moisture.
Thanks all for the help.
I just had my 07 Turbo for two weeks 26K miles, when I got it the oil filler looked like that to and also needed 1.5 litres of oil
So assume its only done short journeys during the winter. It was last service in nov11 and has only done 1000 miles in the last 8 months .
Why any one has one of these and doesnt change the oil after the winter beats me .I usually do it before and after.
The other intersting thig I have noticed is that the water level is on minimum .I topped it up went for a good run and the next morning its back to min
and never dropped any more. No sigighns of any oil in the coolant but difficult to see if there is coolant in the oil with no dipstick hence the need for an oil change.
Has any one else found this ?
On the 996 4s when the level dropped it was a rad cracked , Hope history isnt repeating itself .
Mike
Ongoing reduction in water level often indicates a leak somewhere and a 5 year old 997 is prone to radiator defects.
Debris enters through the air ducts and collects in the corners, right at the back, holding moisture and causing corrosion to the aluminium matrix. There are several exposed rads. in the front of the 911 and one ore more could be affected. Sorry to be glum! [
If you're OK with DIY, there are useful instructions on how to remove the front PU so you can check the rads. yourself.
See http://www.porscheclubgbforum.com/tm.asp?m=613041 (also gives details of fitting mesh to the air intakes).
Hope this helps.
Clive
