I was driving my 987 Boxster the other evening down a good B-road after it had been raining, so the tarmac was fairly damp, but drying. A rabbit decided to run into the road and stop, so not wanting to pull pieces of rabbit out from my radiator all weekend I had to hit my brakes pretty hard and when the ABS kicked in the car very quickly darted left and then right within a split second. It was pretty scary, because if I'd been passing someone coming the other way, or I was close to the grass verge I could have had an accident.
Is this normal for the car to do this, was it caused by the wet road, or do I have a problem with my ABS? When I brake normally, or not very hard the steering wheel doesn't move a millimetre, so I'd guess the discs are fine. They do squeek from time to time also. Is that normal too?
