Is it reaally nearly a year?? Aparently so...
Anyway... whisper it... it runs[
OK... So the problem would appear to have been... having cleaned out the tank when I first got the thing, I assumed the tank to be clear... Never assume... after the first pump not working, the second fitted assumed to have a fault, proven by the third running for a short while, and thinking it must be anything but the pump... I took another look inside the tank... and found what looks like the remains of a scouring pad!
So... I am sure that is not the only fault... but now, having substituted a 944 pump, I got as far as fuel up to the metering head, and pressure at all four injector ports on said metering head. It still wouldn't run.
As a result of pump problems, I now have the fuel pump relay wired through a switch, fuse, and a test lamp (Thanks for the idea Brightside!). Today, I primed the fuel system, until I just heard the injectors squeal (at least I assume that is what I can hear up front), then stopped the pump. Turned it over, and it kicked into life. I could then keep it running, for a couple of minutes, by flicking the pump on and off each time the engine started to die. Hardly the most effective means of controling fuel, but I am a firm believer that the best way of getting an engine running, is to get it used to running!
So... I reckon my problem now is too high a fuel pressure... my question is, is the 944 pump really delivering too much that the pressure relief system cannot cope, or, is the pressure regulator not working, or, could it still be the metering head? Somewhere I have a pressure gauge and hose suitable for measuring fuel pressure on a K-Jet system... I just need to find it... Meanwhile... any comment welcome.
