zwhitea
Hi
My 87 has started to have a noise of what i can only describe as a jammed electrical fan, coming from behind the dash.. but i can not work out what it is.
It only happens after you start the car (so not just with the ignition), but continues on for a good 30 seconds or so after you turn the ignition off..
I have checked all the fans I know of and what is found in the Bentley bible... Internal Temp sensor, both footwell fans, the cold air fan, and the AirCon Evaporator Fan.. but all these are functioning as expected and disconnecting them doesn't remove the noise...
So basically I am not stuck as to where to look next... Any ideas anyone ?
Thanks in advance
Adam.
Thanks in advance
Adam.
