I have been suffering from some brake judder when braking (worse when the brakes are hot) for a couple of years or so, and I've tried the following in a series of attempts to fix it:
- new disks front and rear, plus new pads (Pagid, from Euro car parts)
- another new set of front and rear disks, plus new pads (Porsche-supplied)
- careful check of all bushes
- ditto steering rack, track-rod ends and so on
Disks were very carefully mounted with ultra-clean hub and disk bell faces, and with run-out of 0.04mm or less (allowable limit is 0.08mm) when measured with a dial test indicator.
Result - brakes were fine for a couple of thousand miles and then quickly developed the problem of vibration when used, especially when hot.
However, speaking with the owner of the garage where my day-to-day BMW is serviced, he mentioned that he's had the same problem on several customer cars. He finally noticed that all of the affected cars had had their wheels refinished. On checking the wheels, all had been painted such that the surface of the wheel's web that mates to the disk/hub assembly had a layer of paint on them. He removed this on the wheels of one car, fitted new disks of the same brand that had gone bad before and the problem went away permanently.
Well, I checked my wheels and they had paint on the mating surface. I've now removed this and the problem is diminishing with every drive (I've done about 1,200 miles since).
I cannot be absolutely certain yet that this was the cause, but it is looking very likely given that the problem is subsiding now whereas previously it just kept on getting worse. The only absolute test would be to fit new disks but given the amount of cash and time sunk into the previous sets I am hoping to avoid that if possible.
The moral of the story is obvious, and I hope this information will help someone with the same problem.
