Jump starting another car from my Boxster
- Thread starter flat6
Simply start your car, park within range of the leads, connect the two batteries together, increase the revs of your car to provide a higher charge rate and get someone to turn the key in the flat battery car.
Power spike - balloney
Another battery connected is simply a voltage storage that is empty and requires charge - and all cars are designed to cope with charging batteries, indeed, the alternator outputs approx 14 volts and up to 120 amps - it and the electronics in the car have no issues with jump leads.
The comment reminds me when mobiles were first available - the doomsayers claimed you shouldnt use a mobile in a car when driving because it interfeered with the electronics and particularly the ABS systems, indeed they still say the same for using a mobile at a petrol pump as it will generate a spark and could ignite the fuel - despite the fact this has been proven not to be true.
You obviously don't know what you are talking about Glyn, I specialize in automotive electronic systems and see the results of people putting jump leads on modern cars daily. You are giving people bad advice there.ORIGINAL: Glyn
There are no issues connecting in any order you like, a flat 12v battery is being connected to a charged 12v battery, provided you dont connect the wrong way round or short the battery there are no dangers.
See my website http://www.autolocksmithchester.co.uk/
