On long trips (seems to need a couple of hundred miles before it starts happening!) my oil temp gauge starts to go bananas. It jumps instantly up to max (just above the red area) stays for a few seconds then drops back down to where it should be.
Occasionally it only jumps up to a "hot but not red hot" position.
It is definitely a gauge problem (rather than the sensor) because if I tap the gauge it drops back down to the correct position.
I'm assuming a dry solder joint somewhere inside the gauge. Anyone else seen this/know which joint it is likely to be?
