Just had MOT
jamma
Just had mine done , failed on one thing , a number plate bulb which was replaced, cost of bulb £ 1.08 , cost of fitting bulb £ 22
Anyway bar that all good. One thing though was one of my rears was down to 2.5mm on inside, as I am going to Nurburgring next week apparently under 3mm is illegal abroad !!! I will change them when I get back , hopefully I won't get pulled.
Also they have a funky mobil one oil holder in OCP's now, it comes with gloves and has velcrow on it to attach to the boot , keeps it nice and tidy. I bought one as I though 15 quid was ok, I went to take the oil out and the salesman said it comes with oil so keep that. A one litre bottle costs about 12 quid IIRC so cost of holder works out about 3 quid. Good value IMO.
[FONT=verdana,geneva"]
ORIGINAL: jamma
Think you'll find the LEGAL limit throughout Europe is 1.6mm, though some countries recommend change at 3mm. The rule is 1.6mm across at least the central 3/4 of the tread, all around the circumference, and with visible tread elsewhere.
So the outside/inside edges, for 1/8 of the section width could be down to very little and be legal.
ORIGINAL: DSM
ORIGINAL: jamma
Cheers, this OPC tyre inspection says legal limit in Europe is 3mm!!! But you are right as the rest is 3.4mm and 5mm I should be fine.
