JZ Machtech Upgrade
- Thread starter andcop
The ECU is less noticable but when I had it done the dyno showed my car was down on power and JZM traced most of hte loss to a simple problem with the throttle (only opening to 80%). The combination of that and the ECU really did make a difference!
Charlie
p.s. the other decent thing about the suspension setup is that its not stupidly low - my 993 gets over bumps/dips that hit a 996 chin spoiler every time.
micksummer
I later had the Monoball solid shock mount installed as well which sharpened the steering no ends, although you get a fair bit more road noise.
I beleive they stopped doing the Roock kit, and started using the Manthay ones now.
Out of interest did anyone change the stabiliser bars?
The originals are 20mm Front and 18mm Rear.
The MO30 bars are 22mm and 20mm respectively with the turbo bars 1mm bigger at the rear?
Not sure what this would do and if for normal sport driving this would make a noticable difference?
Andy
oliverjamesthomas
H&R are available from the continent at 26mm front, 24mm rear. Price is reasonable at about £260 per set, although would they be a bit too extreme at those diameters?
