JZ Machtech
- Thread starter Diver944
Hilux
Included was a full inspection and report, rear offside bearing and new thermostat.
I have absolutely no issue with what they did and the cost was reasonable and all that was done was thorough.................HOWEVER..................
I wheel has additional scratches, there is a fine but non polish outable etc scratch on the bonnet and the car was absolutely covered in grubby handmarks, finger prints etc. It had been washed but washing alone doesnt get rid of greasy marks.
The car isnt new so its difficult to argue that the damage wasnt there before but it is not far off being pristine/concours body wise so there arent many marks anyway apart from front end stone chips.
Im not a complainer but I am annoyed. I feel that it if it was a 993 it wouldnt have been handed over to me in that state. Anyone else had the same issues with their car (not necessarily at JZM)?
carlmthompson
They have a reputation to maintain!
Do you mind me asking how much the bill was? My 12k Service + Fuel Filter + Coolant Change + Plus Front Brake Pads was £530, so wondering if it was similar.
Hilux
12K service (less air filter as I have a K&N one apparently), replace thermostat, coupla bulbs, OEM DME relay as it an aftermarket one known to fail apparently and check its operation (car definitely `seems` to run/tickover smoother but it could be my imagination, check rear wheel bearing noise (its not the bearing its the transaxle pinion bearing (£1000 to replace[
Not cheap but not bad IMO service is about 280, thermostat was 85 plus parts, lubricants etc etc and vat
Mrkjblue
My first Porsche was a 1982 944 lux around 6 years ago and it was very rough on the outside, I had Machtech change the cam belts and during this they managed to dent the bonnet, looked as if they left some tools under there and slamed it shut.
After I pointed this out Jonas (sp?) had dent master out the following week to fix at there expense, no questions.
Never had a problem with their service since, although they did start to get pricey so I've used a few others, but would reccomend them.
I doubt they care what your car is - £500 is £500 quid whether from a 993 owner or a 944 owner. They are getting pricey though....[8|]
Diver944
Yes, they are getting a bit pricey now, but isn't everyone. A local mechanic to me who services the Mrs's 205XS (quite sporty, and not too fast for a girl!) charges not much less per hours and he doesn't have anything like the facilities of JZ.
I always find JZ helpful and Jonas and Dave always have time to talk for a few minutes about my car.
kevinshally
I'ld bring this to their attention.
As for me, got the car back last week. 1st drive in it and got a stone chip on the brand new windscreen. Grrr. It's back in the garage now because the roof has a personality of it's own. Sometimes will work, sometimes will not.
Saw a mag of 944s2 from 2002 and it seems prices for top quality cars might even be going up a little.
Kev.
944turboS
Hope your wife doesn't read the forum
