Just in case anyone is interested, EuroCar parts have a discount online deal going at the moment, I think until the end of the week (code is CRAZY70).
I have a 981 Boxster which I have owned only for 4 months but I have been using K&N filters for nearly 40 years so it was always on my radar to fit K&N's to the Boxster.
They normally retail for about £61 each (you need 2) and I got mine today from EuroCar Parts for £39 each.
They are an easy fit through the boot access.
They do not need oiling as they are pre-oiled prior to fitting for the first time and I got this response from K&N today as I had heard rumours about the filter oil playing havoc with the mass air flow sensors.
The oil does not come off of a K&N air filter when it is in use, even when over-oiled or in extreme air flow rates exceeding 1000 CF'M.
If somehow K&N air filter oil were to make contact with a mass air sensor, the oil would not cause the sensor to fail. We have intentionally coated mass air sensors with our filter oil, and monitored the sensors' output when installed in daily driven vehicles. These sensors continued to function normally, even after being sprayed and submerged in K&N air filter oil. K&N air filter oil does not cause problems with mass air sensors.
These are for life air filters and can be cleaned & re-oiled at 50,000 mile intervals.
You can buy cleaner/re-oil kits from various suppliers.
The K&N part number is E-0666
