Key fob not working properly….
- Thread starter PaulJ
In answer to your first question, no the key fob isn’t charged when it’s in the ignition so you’ll need to replace the battery.
There’s plenty of information online on how to replace the battery, but here’s an example:
https://boxstertips.com/porsche-boxster-987-key-fob-battery-replacement/
Pay attention to the possible need to reprogram the key fob after battery replacement which pairs the key to the immobiliser.
If you got a spare key when you purchased the car you should be able to use that, although you may need to carry out the key pairing procedure if it’s not been used before.
Jeff
Can anyone confirm whether my key fob should "charge" or whether I need a new battery…. And if so do I need to take it to the OPC to do this, or can anywhere like Timpsons for example do it?
Thanks Erica
Motorhead said:Hi Erica,
Jeff
When I bought my 987.1 (private sale) one of the keys wasn't working.
I replaced batteries in both fobs.
One remained working, the one that wasn't working, remained not working.
Mentioned it to Mike @ Zentrum when they were replacing a/c condensers and they re-paired the key at no extra cost.
I don't know how to re-pair them yourself though.
![Key :key: 🔑](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f511.png)
I do appreciate everyone sharing their knowledge…that’s what makes the PCGB so special.
thanks Erica
Any help would be gratefully appreciated[
If you've tried the re-pairing the key and it failed, then I guess getting that to work is going to fix everything. Can you and/or your Indie have a go at re-pairing the key to see if they can sort it cheaply?
If the vehicle is not started or unlocked with the remote control within 7 days, the remote control standby function is switched off (to save the vehicle battery). 1. In this case, unlock the driver’s door with the key at the door lock. Leave the door closed in order to prevent the alarm system from being triggered. 2. Press button 1 on the remote control. The remote control is now activated again
Dan
If in doubt, read the Manual! [
Erica, have a look in your Driver’s Manual under Keys for more information. It’s from page 11 in my 987.2 Manual and probably the same for your 987.1, and the procedure which Dan mentions is on page 12.
Hopefully that will cure your problem but if at all possible stay well clear of the dealer network as their labour charges seem to have skyrocketed in the last 18-months or so … around £150/hour by my reckoning!
Jeff
Personally, I don't think this is a sleep issue - the car is awake once you have opened the door and started the engine ( and for what it's worth - the car actually wakes from it's "sleep" when you lift the drivers door handle (at least on a 987.2 is does) don't know why that's not mentioned in the manual....)
Assuming the remote has worked previously ( i.e. since you have had the car ) then we know it "should" be ok - so there are a couple of things that you can try
1) Try putting the battery in the WRONG way round briefly ( silly as this sounds, it is known as a method to "reboot" the remote logic in the key - although I have seen this documented for a 986 - so maybe not applicable to a 987)
2) If that doesn't make any difference then it can be out of sync with the car ( the codes "roll" in both the key and the car as it gets used - with a bit of an overlap - but if a key has been out of range and pressed a number of times - like when a toddler is playing with your keys - then it can go out of sync ) - same I guess can happen if the battery has been dead for a while and the car opened by the key - I don't have my manual to hand - and this is from a US version of the manual - but it says.....
Operational readiness of the remote control interrupted Encoded data is transmitted to the vehicle each time the wireless remote control is operated. If the remote control is operated too often outside the range of the vehicle, this can result in the central locking system no longer responding. In this case, the remote control and vehicle must be synchronized. Carrying out the synchronization 1. Unlock the driver's door with the key at the door lock. 2. Open driver’s door and insert the ignition key into the ignition lock within 10 seconds to prevent the alarm system from being triggered. 3. With the key inserted, press and hold button 1 on the remote control for approx. 5 seconds. The synchronization is now complete.
Button 1 is the "lock/unlock" button as far as I know.
I have seen other internet hits suggesting you hold for 30 seconds, and others saying the "locked" light on the dash flashes and/or the horn sounds - but the above is from the handbook - so I would start there.
Hope this helps.
Two things firstly how long was it between the last time you used the car and when you first noticed it was not working ? And how long was the battery out of the key when you changed it ?
If the battery was either flat too long or out of the key more than say a minute the key forgets that it is synched to the car and will need to go to opc or good specialist, when I worked in garages we used to get people coming in to buy a new battery with the old one in hand only to be told it wouldn't work remotely until we had reset it, I think the opc were confused as to what you meant when they said it wouldn't work if not synched as it will still unlock if physically in the door handle and as others have said the immobiliser is just a chip in the key
So we:
1. Unlocked the driver's door with the other remote (I guess you can use the key) 2. Open driver’s door and insert the ignition key into the ignition lock within 10 seconds ( to prevent the alarm system from being triggered if you use the key.) TURN THE CAR ON PROPERLY (ie start the engine) . 3. With the key inserted (and the engine on), press and hold button 1 on the remote control for approx. 5 seconds. (we needed 10...) The synchronization is now complete. It didn't pair for me (or the technician) when we only turned the key one notch(so the lights came on, but the engine wasn't started). Button 1 is the "lock/unlock" button as far as I know. Yes, you're right it is.
We also didn't get the "horn" sound to indicate pairing, so there is some stuff out there on the net that is slightly wrong.
And the really good news is it took about 5 minutes and they didn't charge me anything. So I gave them two bottles of wine for saving me a fortune at OPC....
So all credit to 3D Autokeys for being really helpful. https://3dautokeys.co.uk/
Thanks everyone for their help. And the lesson is - replace your battery as soon as it starts to reduce the distance you can open the car from.....
Erica
