2001 996 cabrio. Last night the key fob activated "button" stopped locking the car. There has been no forced entry and the car was fine ealier during the day. The fob flashes when pressed, but the only way to lock and unlock car is with key in door, key has to inserted into ignition immediatly to stop alarm sounding. Any ideas have read Richard Hamiltons FAQ. but I do not have to revert to emergency procedure & therefore wonder is there something else that might be checked. Any clues/tips would be appreciated. thanks, JJ.
Key fob Remote locking failure
- Thread starter jeremyj
Try this:
Lock the car with the key & wait a minute for the alarm unit to 'settle'
Unlock the car with the key and immediately press the button on the remote
(this should disarm the alarm and dispense with the need to inset the key in the ignition)
Now try using the remote for the complete operation.
My alarm unit occasionally refuses to repond to the remote ( despite changing the battery), but after carrying out this procedure all works again OK.
Good luck
Good luck
ORIGINAL: concept
Try this:
Good luck
'Concept', are you sure that your remote is not working purely because you've not used the car for 5 days?.
If it's less than 5 days and this works that's good news and I need to try it with my key which stopped working for no apparent reason.
ORIGINAL: danofesher
Good point. No, can happen anytime outwith 'sleep mode' - however now that you mention it, the problem is almost as if the alarm unit has (prematurely) gone into sleep mode - because the recovery procedure is the same. I.E the remote will never work again until the key is used to unlock.
