Key Fob
Porrohman
My key is so sensitive that picking it up triggers the front bonnet to open. Is this commonplace or do I need to change my key?
Sadly it is common complaint. [:(]
Your dealer can extend the time it is required to press the button prior to opening it, this can help in most circumstances..
Garyw
I had a similar problem
There is a repalcement "button" set for your key fob, where there is a guard fitted that reduces knocks depressing the buttons and they seem to have reduced the sensitivity of each button - try yur OPC
Prior to fitting the replacement, I could turn the alram off and open the windows from the far side of the house
I had this fitted (FOC) from the local OPC and it seems to have made a significant improvement
