Key fobs not working!
- Thread starter skendrick
There are a couple of fixes like putting the batteries in the wrong way round (reverse polarity) or putting the key in the ignition and pressing the lock button twice.
If neither of these work then I think you might have to go to your local dealership to get them reprogrammed !
All this reprogramming stuff might sound frighteningly expensive but at least the system isn't as stupid as that adopted by BMW (and some other makers) since that allow any scrote with a laptop to program a blank key with a laptop plugged into the ODBII port - and then drive off with your car.
There are 3 elements to the key. The blade, the immobiliser pill, and the radio remote.
The blade is obvious. You can buy a blade, ready cut to the car, and this can be ordered from the vehicle VIN. The lock numbers are stored on Porsche's IPAS system. You can buy blanks, and have them cut, but you can also get them cut to a photo of the key. Surprisingly, this works well, and you can find sellers on eBay.
The RFID pill is programmed to the alarm module, but in the process a code is written back to the pill. This ensures that the pill can only be used on that car. It cannot be programmed to another car. I have never heard of a pill going bad.
The remote heads come with a 24-digit code on a tag, which is entered during programming. Porsche do not store the remote codes on IPAS, so they cannot be reprogrammed to your car. If you buy a used key, the remote will be useless without the 24-digit code, as will the immobiliser pill.
berrytastic
With the smallest window of sun at the weekend, the roof was down smartish, but I could not open teh roof with my key.
I pressed the button, the light flashed, but no magic. I had to use the button on the dash.
Can the key ne resynched or is the same issue as above, new key remote bits?
Oh the central locking function does work, but can sometimes you need to be very close and pressing for a second or two.
thirteeneast
http://forums.rennlist.com/rennforums/3054113-post19.html
You may need to register if your not already.
