Just started to experience an issue where the key will not remove from the ignition, even though gearbox is in 'Park'. Have managed to remove it eventually on each occurrence, but only by moving gear lever several times between Park and Neutral. One minor clue is that the dash indicator still shows a flashing indicator for Reverse even though lever is in the Park position. The dash indicator is flashing though rather than the solid indicator when it is actually positioned in Reverse.
Any advice would be appreciated.
