KN ashtray removal - how?
- Thread starter swiftus
I have tried pulling it out, maybe not hard enough. Yet!
The hand book says a release lever has to be moved and shows a picture of it, but it's a differnt setup to mine. The difference seems to be the non-smokers pack that mine has. The discription in the hand book shows the tray with a 9v/lighter provided and the release lever, mine doesn't have either of those.
I am wondering if my isn't supposed to come out as it isn't supposed to need cleaning (as an ashtray would)?
Frutti_pig
You'll need to remove the AC control panel, but first you need to remove the aluminum look trim around the console, it just pulls out. After that you gain access to the clips which hold in the AC control panel. There is metal tang that holds it in on each side. You need to press those clips towards the center of the car and pull the control panel out, its kind of a pain. After that youll see two t-20 screws which hold the ash tray in.
Fingers crossed!!!! [][][]
Cheers FP
