I have a knocking noise which seems to be coming from the rear wheel on the driver's side.it only occurs when the car is in gear,yet when it is in neutral and coasting it goes away!how odd?!does anyone have any suggestions as to what it could be?i think it might be the cv boot joint but am not sure....[
knocking noise on rear of boxster s 2002
- Thread starter leeroy
Yes could be cv joint look under car and you may be able to see if it's split and throwing the grease out, also check to make shure the wheel is tight. Berny
