KW suspension
- Thread starter BIG UN
Steve Brookes
Moderator
Dave Wilkinson
I'd agree with everything that Steve says - but I would ask myself if you would consider getting twice the value from a KW setup considering it's pretty much twice the cost of a Bilstein/H&R setup. Undoubtedly the KW setup has distinct advantages for track use, but for road/everyday use the chances are that you'll set the bump and rebound settings once and never touch them again.
There are advantages both ways - it's just a matter of deciding where your priorities are.
If you hadn't guessed already, I'm quite happy with the Bilstein/H&R setup on my car - and mine is solely road use too.
Dave
Steve Brookes
Moderator
Steve, that is a good price on the KW's and if I get the right deal that I'm after then should come in
around that figure. They do seem to be the favoured suspension set-up at the moment and as you
say a good selling point. Although after this and an engine rebuild I should think I'll be buried in it!
Dave, equally good point although price-wise I would say there seems to be only £300 or so in it,
unless I'm missing something? Are we talking about the B6's? As you say I'm likely to set it once and forget it, but as far as I can tell the Bilsteins are more fit and adapt to it if that makes sense?
So far between yourselves and Sundeep on 911UK I think I'm being turned toward the KW's.....
.....unless Dave can pull it back.[]
Thanks again.
Andy.
turbo jonny
more to get the KWs. so i did for the reasons given by steve. Glad i did ! Both cars were set up by the same garage
( red line racing ) for mainly road use and i am more than delighted with the KWs.
Dave Wilkinson
ORIGINAL: BIG UN
Given the current dollar and euro exchange rates it looks like the pricing tends to favour the KW solution. Back in late 2007 when I did mine I got the Bilstein HDs for under £450 landed from the USA. With the H&R Green springs that I already had, coupled with a good deal I got from RPM to fit them and from Center Gravity to set it all up it was really a no-brainer for me. If I were to make the decision now I may come to a different conclusion.
Dave
Steve Brookes
Moderator
Mine skips/hops in bends with uneven surfaces (not braking) - too hard at the back?
My suspension seems pretty harsh altogther for my needs (it is lowered quite a lot). 'Crashes' a bit at the back too over straight line bumps. How much might it cost to replace all four corners with mid-price kit. No racing, just brisk weekender stuff - nothing too sophisticated needed. I am taking it to Ray Northway on Saturday for him to have a look at too.
All the best
Des
Steve Brookes
Moderator
Konstantin
I have KW V3 for a few years on my C4, there are set up quite hard, first I found the car skiding arround and not haddling very well, I finally found the tyre pressure being an issue, I now pressure them cold at 30/34, recheck hot road or motorway arround 32/34 and rear 36/38, I am on 18" 225/265, R888, geo is RS with almost 2 deg camber
Konstantin
