marcoturbo
The KW V3 kit I bought several months ago has been installed on my car since less than 24 hours !
I now need to get a whole alignment job to be done with torsion bars reindexing. I've searched about specifications used with KW V3 but can't find what I seek for.
My car is only a street car, no track (sometimes very loaded due to the roof rack )
What are the specifications you use with KWv3 ? Stock camber, caster and toe-in specifications ?
I'd like to put more negative camber than stock to be able to fit my 16x8 Fuchs (rear 951 wheels) in the front without rubbing fenders (I currently have 7mm spacers to clear the 993 (928s4/944M030) front calipers). What range can be used for street driving ?
Any advice welcome !
I forgot... I adjusted rebound and bump following KW instructions
Thanks.
Thanks.
