KW V3: uprated rear springs?
- Thread starter Guest
I installed the fronts tonight and have been driving ever since (it's about 0200 now). They are simply amazing! I'm running them just as they came out of the box and haven't changed any of the settings.
The car is so flat, yet rides so good, there has to be a catch. They are especially good under hard cornering on bumpy or uneven surfaces. I'm actually glad I did just the fronts, as I can get a better appreciation of the differences.
Hopefully Dave can tell me how to swap the rear springs so I can get the full effect.
Well, I better get some sleep!
Big Dave
Yes the rear shocks do come apart...I fitted stronger springs to mine, BUT it was about 18 months ago...
If my memory serves me correct,the bottom mount cant come off because the offset bottom eye bolt is in the way, so the top eyelet must have unscrewed...It was tight though....
Have fun...
Big Dave
The KW,s you have , Have they been custom made to run with a T bar removed.??
I only ask the ??? as the valving in the KW is made to be used with the T bars still in place. If you then remove the T bars + fit stiffer springs to compensate, youl put the shocks under a different loading + poss wear out the internal valving , as they are working harder...
I see what you mean about the rates Dave, and I had the same concerns. The KW engineers approved the setup though. So in the end I took the chance. It's tough to order anything besides the V3's in the U.S.
Looking at your engine it seems that it has a lower center of gravity than the i4 motor and I believe the weight is actually very similar?
I actuallly tried to post the same pictures that you have of your beast but they were too large. You must have reduced them? Cool pics.
Neil Haughey
Wow, great eye, it is lower than the i4. Weight is really close to the 2.5 8v turbo and I/C combo. The LS2 gets a little lighter by removing the Vette cast-iron exhaust manifolds, and using headers in their place.
RHD and V8 fitment.....that's got me wondering if it would work!
Thanks guys.
