KW for sure. It is really great stuff. It transformed my old 944. I've still not driven anything more modern that felt as nice - that includes passively sprung Boxsters and pretty much most of the modern hot hatches around at the moment. It was stiff yet compliant - which sounds odd and contradictory and i've never felt anything like it before - I guess it is probably what a modern Porsche with PASM must feel like (which I havn't had the pleasure of driving). The place I got mine installed at, had just installed a set on a 993 turbo after its owner had run with the usual Bilstein M030 setup and only hacked it for about 1 month before he gave up with it on account that it was too stiff for the roads. The KW is equally as stiff, if not stiffer and apparently it drove much better over the bumps. The clever bypass valve setup works really well. It is pricey, but a very well built bit of kit constructed from stainless steel so after a few years it wont look all rusted up.
The only downside to it is that some of the damper adjustment screws are a bit inaccessible, but in reality who really messes with them? in 99% of cases once the initial novelty has worn off it is basically a case of set and forget.
