Laid up for the winter advice PLEASE
- Thread starter SEE YA
metric_thumbs
I would change the oil, push it into the garage, and, if you can, take each plug out and put a very little thin oil into each cyln, screw plugs back hand tight and then spin over without any HT leads for 30 seconds and then leave it.
Another good thing might be to push the CIS flapper down and let it return once every 2 months, this will keep the fuel head from getting stuck. Do it with the ignition on so the fuel pumps run.
Put the car on axle stands to keep the tyres from flat spotting.
Disconnect the battery and charge it once a month.
The only other worry is the fuel going off & varnishing, they make stuff to put in the fuel but I have no experience of this.
I do look for a dry day every now and then if I get time and take it for a spin, but can recall many winters where it has just sat there.
Simon
jamescharnley
Best thing to do is pay for that little bit of extra insurance & keep the car mobile, so when you wake up one crisp dec morning , look outside see the roads are dry & salt free you can jump in the car & give it a good work out. At least this way you don't have to worry about rubber hoses going brittle , seals hardening etc etc . It also does wonders for your own sanity
EDIT: Just read the bit about you being on the other side of the world [
SEE YA
ORIGINAL: 911addict
Seeya, fair enough.
And I thought it was just a garage queen! Just joking, I know you took it to Lemans this year, as did I.
Yes did you see it there I was parked near the top by the tables E911 *** on my no plate?.
SEE YA
Yes, it's true that not using the car will cause problems, but these problems are all things that can be unbolted, replaced or repaired and bolted back on.
Using a car in winter in UK will eventually mean rust will form and then the car has to be welded. My 3.2 carrera has never been welded and I would prefer to keep it that way. Having passed a welding course I can tell you that just because a weld looks good does not mean that it is. Also corrosion will weaken metal. When a car is welded there will be parts of the metal that has the paint or coating damaged from the welding nearby. This then can cause more rust from condensation etc etc.
I had the privilege of meeting a guy nearby last week that has spent £21K on a body restoration of his 1988 3.2 carrera. [:'(]
I found my 930 a waste of time on damp roads.
911addict
Seeya, yes I saw yours, it is in great condition, and was surprisingly clean? Mine was dirty and parked next to the 360 Stradale.
