Ok chaps so the story continues.
Having failed to get the original Porsche lambda bung out of my turbo up pipe I have been pondering other mounting methods.
Option 1. Weld a ferrule into the existing exhaust. The problems with this is I haven't got a welder so I would have to have the job done and I'm not sure that welding is a good thing for the electrics. I would also be worried if the hole was put through up stream of the turbo that an errant bit of swarf could get pushed through the blades.
Option 2. Replace the section of exhaust with one that the bung comes out of or have an alternative section replaced with a ferrule welded in before fitting. This seems and expensive option. I have been discussing this with Simon at Essential Styling with a view to having a ferrule mounted on a new de-cat section of exhaust. This would work but would put the sensor in the turbulant air on the exhaust of the Turbo, which can't be ideal, or would be a long way down the pipe.
Option 3 Have a saddle made up and jubilee clip it to the exhaust with plenty of exhaust paste behind it. The exhaust would be drilled prior to mounting the saddle to give access for the lambda (obviously). This should be a less costly option but still needs to be mounted "down stream" of the turbo because of the swarf danger as noted. Once the saddle has been fabricated it is a D.I.Y. job but I wonder how good a seal can be achieved or maintained.
What do you think chaps?
