Lambda sensor
mr pg
From the cat, where does it connect to at the other end, as I'm about to replace mine? Hope it's easily accessible? Anyone have picture that might show it?
Thanks, Paul?
Paul,
I'm afraid I can't be absolutely sure since I've not done it myself, but I have a feeling the other end of the cable goes through the bodywork via a grommetted hole and connects to the wiring loom inside the engine compartment in the area of the rear blower. There are a lot of connectors in that area, most of which are assembled onto a metal bracket - and I think the oxygen sensor connector is one of them.
BTW, good luck in getting that sensor out of the cat. It usually gets virtually welded in place by the extreme heat and I have rarely heard of anyone extracting it unharmed. Since they do expire after a while anyway it would probably make sense to go with a new one. The watchword is to make sure you replace it with a pukka Porsche part since apparently the Bosch ones are not as well sealed against water ingress and suffer a bit in heavy rain.
Dave
Thanks Dave, but wish I'd seen that before buying a Bosch one on the way home tonight! Oh well, it's a fair weather car, so hopefully won't be seeing too much heavy rain.
